how do I make a smooth connection between a sphere and a non curve?
We can help better given a picture or a public document.
here, Got it here
https://cad.onshape.com/documents/6ea0d8be5ab5f2685415db1f/w/0221899d8f6095131a372051/e/32fb743a55d5e937e6cb9865?renderMode=0&uiState=68c967397b2b03dc8f407d6e
also, I accidentally made the versions wrong. The version that says a version of curving is the original and the main one is my thought on how I should. I wasn't thinking very well.
you'll probably need to be looking at using the loft tool in some way. How depends on the final look your going for.
Something like this? Quick and dirty:
https://cad.onshape.com/documents/b345ec39a19ef2c07d08e8fe/w/eb8d3dff5072fe0dde93f94f/e/e198e2ea726afbfd2d17c041?renderMode=0&uiState=68c9aee4c5fdb38b40539680
If you knew you wanted a smooth transition right from the start, you'd probably have started different, right? The origin is your friend. If you don't hide him but rather build symmetrical parts on him, he'll save you a lot of work.
