hole with 2 diffrent sketches
Hello, I'm new to this and have taken on a difficult task. I want to build a holder for my PS5 remote. I want a square shape on the outside and a hole on the inside with the same dimensions as the remote control. It's round from the front and a little bit like an elypse from the side. How could I create this drawing? I was thinking of maybe an ellipse on the top and a semicircle on the front. Then you would only have to connect these two shapes three-dimensionally, but I don't know how. I tried using the sculpting method, but it only takes two sketches parallel to each other. How would I do it with two sketches 90 degrees to each other?
Mabey the picture below helps to understand
Thanks in advance to anyone who can help me.
Maybe something like this.
https://cad.onshape.com/documents/8599b97967bf83834614d764/w/37f28f6d0a15921bdd09c854/e/3063adce10640f11d1eb5be9
