Improvements to Onshape - September 19th, 2025
mlaflecheCAD
mlaflecheCAD Member, Onshape Employees, Developers Posts: 208 image
edited October 2025 in New in Onshape
This release introduces the powerful new Assembly Mirror tool, connection to Arena PLM Enterprise for AWS GovCloud with Onshape for Government as well as a number of user interface, drawings and performance improvements.
CAD IMPROVEMENTS
ASSEMBLY MIRROR
Mirror parts and subassemblies with flexible strategies for symmetric and asymmetric components, mirrored motion, and integration with versions, configurations, and release workflows.
https://onshape.wistia.com/medias/j68taf1nt7
This is a deep and complex feature.  As with any major new function, we welcome you to share any improvements you would like to see implemented with us.
CONFIGURE SKETCH PATTERN INSTANCE COUNT
Onshape now supports controlling the instance count of patterned sketch geometry through configuration controls.
https://onshape.wistia.com/medias/vkxsau9jqc
DRAWINGS IMPROVEMENTS
NAMED VIEWS IN DRAWINGS
Named views with section cuts created in Part Studios and Assemblies can now be reused directly in Drawings, with support for the Exclude option.
https://onshape.wistia.com/medias/21s7sv2rg8
BOM CALLOUTS
Structured Bills Of Materials tables at the top level can now reference views of subassemblies. This allows a single BOM to drive balloons across subassembly views, removing the need for multiple BOM tables.
https://onshape.wistia.com/medias/9o76zj4trd
JIS DRAWING TEMPLATES
Onshape now supports Japanese Institute for Standardization (JIS) drawing templates. Select JIS under Custom Templates and use the provided A0–A4 templates as a starting point for your drawings.
https://onshape.wistia.com/medias/fv734h1mix
DATA MANAGEMENT IMPROVEMENTS
ACTION ITEMS SEARCH AND FILTER
The Action items panel has been updated with a new layout and tools. The Create task button is now at the top, a Search bar makes it easy to find tasks or comments, and filters now include Assignee, Part number, and other task properties.
https://onshape.wistia.com/medias/2wipmn8d0o
DRAG AND DROP INTO FOLDERS
Documents can now be organized with drag-and-drop into subfolders from the list view.
https://onshape.wistia.com/medias/0ql0947fh4
ONSHAPE FOR GOVERNMENT CONNECTION TO ARENA PLM ENTERPRISE FOR AWS GOVCLOUD
Onshape for Government now connects with Arena PLM Enterprise for AWS GovCloud, creating an end to end, secure, cloud-native environment for CAD, PDM, PLM, quality, and supply chain collaboration, helping government contractors and defense organizations work with greater accuracy and confidence.
https://onshape.wistia.com/medias/lqzg69ezdj
ONSHAPE FOR EDUCATION
PREVIEW AS STUDENT MODE
Onshape Educator now includes a new Preview as student toggle, allowing instructors to view classes and assignments exactly as their students see them.
https://onshape.wistia.com/medias/bcj4i3jlba
CAM STUDIO
COMPONENTS LIST UPDATE
The components list in CAM Studio has been redesigned to match Onshape’s UI. It now shows parts, stock, and workholding, with options to hide, show, delete, or open referenced items for faster access and control.
https://onshape.wistia.com/medias/1okhqf1153
RENDER STUDIO
QUICK UPDATES TO REFERENCES CHANGES
Render Studio now updates geometry and configuration changes without reloading the entire scene, improving workflow speed and making it easier to work with evolving designs.
https://onshape.wistia.com/medias/wow6e11b7y
ORIENTATION CONTROL FOR FILAMENT APPEARANCE
Added Orientation ▸ Rotation (X, Y, Z) controls for filament (FFF) appearances, allowing simulated layer lines to match the actual print orientation instead of being limited to vertical or horizontal.
https://onshape.wistia.com/medias/fmonjevz6v
Regards,
Mike LaFleche   @mlaflecheCAD
«13
  • david_littlefair373
    david_littlefair373 Member Posts: 11 PRO
    Assembly mirror but still no assembly planes!
  • Konstantin_Kolegaev
    Konstantin_Kolegaev Member Posts: 3 PRO
    MADE MY DAY!!! MIRROR IN ASSEMBLY!!! THANKS!!!
  • GlendonKuhns
    GlendonKuhns Member, csevp Posts: 40 PRO
    Thank you so much for the Assembly Mirror feature! It will save me a significant amount of time in the future, as well as reduce the likelihood of user errors.
    S1mon Member Posts: 4,395 PRO
    Yep. I cringed each time @mlaflecheCAD created an implicit mate connector in the demo video on an edge which is likely to change or disappear as the design evolves.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,814 PRO
    Easy enough to add explicit MC to any of the main part CL (or directly in the assembly)… You can just create an implicit MC at the origin on the fly in any of the 3 axes so not sure what the big deal is…
    I don't work a lot with symmetric assemblies so this hasn't been a huge issue personally but it looks to be nicely implemented!
    Named section views in drawings are going to be a lot quicker to setup! Now we just need the ability to control the "regions" that are cut when using multiple section planes!
    Also pretty excited to not have to reload the whole render studio to change configuration!
    @eric_pesty It's easy for you or I to add/create the mate connectors, but much like manually resizing datum planes, it seems like something that we shouldn't need to do. Also having been around a number of very smart engineers at a couple companies who are relatively new to Onshape, I would say that the lack of an obvious way to pick a default plane/axis is really a stumbling block. For certain types of parts in an assembly, it makes creating cross sections impossible without adding MCs or other extra references.
  • lougallo
    lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,018 image
    Correct we are not flipping thread tags in the hole feature but if you model threads it will.
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,057 PRO
    Love the implementation of the different strategies being applied on a per-part basis and warning you when you're about to generate 8 left handed variants of parts before you let the assembly mirror rip. Now I'll just need to keep an eye out for my team members' data practices to make sure I don't end up with a left handed fastener library accidentally like last time.
    I do see an gap in the derive mirror workflow where the way it would work as implemented you might find yourself mirroring a part and then selectively unmirroring faces and features on that part. Might call for a sequel to Lefty Flip. Time to write Righty Flip?
  • brucebartlett
    brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
    Yes, this has made my day—mirror in assembly. Looks great, and I can not wait to use it. This should hopefully save days, if not weeks, of work per year.
  • eric_pesty
    I'm guessing you are talking about adding feature to the "original" part after it's been mirrored in the assembly but not propagating these to the mirrored part?
    I would think that making mirrored parts "different" should be a bit of an edge case.
    Might be easier to mirror the part in the part studio for these cases…
    Probably more applicable to assemblies, although here it looks like you can already suppress some of the mirrored items and add other ones in the mirror assembly so easy enough to create a "mostly mirrored" assembly!
    Just found an improvement opportunity: it's currently not possible to manually configure things in the mirrored assembly. So if you add an extra part and or suppress something from the source, you can't add that to the configurations.
    I can understand how adding configuration inputs in there would get messy but adding stuff to the exiting ones would provide even more flexibility!
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,249 PRO
    I'd like if any of the 3 "planes" of a MC could be used, anywhere a MC is referenced. Either as a sketch plane, or a mirror plane, etc. Limiting it to the XY "plane" of the MC is annoying, IMO. Thanks.
    It's also quite neutered. You can't even reference a MC to place another MC.
    No it's a bit more edge case than that even, but something I run into often enough that it's a reason I developed Lefty flip. Say you have a purchased part that comes in only one handed configuration but you need to make left and right handed assemblies to wrap around it. Squirrel cage blowers are my everyday example, they only make em in one spiral for the products we use. To make parts that interact with these, the hole patterns and pockets and features that touch the purchased part won't want to be mirrored, but will be integral to a part which must otherwise be mirrored. So I have to mirror the whole part minus a handful of features on the part.
    Lefty Flip enables me to just define all the inverting stuff above the mirror in the tree, and non-inverting stuff below it which makes all the IDs work out upstream in an assembly because the faces are the same just transformed.
    Righty Flip would be the opposite direction where you've got your assembly mirror derived studio part with all the faces and features that were mirrored from the original and you want to flip some back the other way because you forgot that you had modeled thread geometry that's now opposite handed and you need the undo button.
  • MichialAnderson
    MichialAnderson Member Posts: 7
    Can I mirror a full assembly or will I have to make it a "sub assembly" in order to mirror it across
  • yonatan_cohen872
    yonatan_cohen872 Member Posts: 4 EDU
    when is onshape CAM coming to EDU?? isn't it supposed to be there already?
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,363 PRO
    This entire update looks terrific to me, especially the assembly mirror. Mirror has been a long waited feature but the implementation is great and worth the wait.
  • MDesign
    MDesign Member Posts: 1,458 PRO
    perhaps mate connectors need a hip cool new name that would be all the rage and go viral.
