How do you design a car in onshape
Ideally KTM Xbow GTXR?
  • martin_kopplowmartin_kopplow Member Posts: 1,300 PRO
    edited September 2025
    Usually, you'd start out by taking car design classes at some universitiy during daytime, and you'd probably work through the Onshape leanring center at nights, and after that, you practise a little, take an internship at one or two well established design bureaus, where they make you work with old school stuff like Catia and SolidWorks, and after that you get back to using Onshape and woosh! - you should be just fine and hit the ground running in no time.
    Dou you have any more specific questions?
