CSV to Sketch - Custom Feature
Caden_ArmstrongCaden_Armstrong Member Posts: 412 PRO
Introducing a new custom feature for importing CSV points as sketches.
This feature takes in a 2D CSV of coordinates, and generates sketch points, polylines, or splines.
Polylines and splines can be broken up by inserting a blank row into the file.
Get it on fs.place (The only marketplace for custom FeatureScripts), or from the public document
  • MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
    Another great feature! Your on a roll bro: 🏆️
    RENDERCAD
  • christian_diestelchristian_diestel Member Posts: 2
    Hi, I've tried to use your feature, but it's not parsing the csv file properly. No points are shown. What format does the file have to be in? What delimiter and line break character are required?
  • Caden_ArmstrongCaden_Armstrong Member Posts: 412 PRO
    edited September 2025
    The delimiter is just a comma, and each data point needs to be separate with a new line character. Extra blank lines will separate groups of lines.
    The forums mess up the format, but you can see the example file in the document.
    But for example:
    1.0,2.0
    4.5,6.7
    33,44
