Auger screw to sheet?
marek_zbikowski
Member Posts: 4 ✭
Hi. How can I transform auger screw spiral (1 turn) into a flat sheet metal surface?
I've tried the available options, but I can't seem to accomplish it. Here is the link to the project I want to replicate on a piece of sheet metal and then bend it:
This is for my personal hobby project that will be done in future, and i want bend it also myself. Draw flat will be usefull to cut sheet before bending.
I saw YT videos that someone do it in SW but this software is some problematic to me, i make few draws in onshape and im still looking way how to do that here. If sheet option will not work, maybe it is any other way to do that? This looks like big challenge
Not sure where everyone gets the idea that this can't be done. Screw flights are made from cut outs of sheet metal. Some are also rolled flat bar. Solid works have an option on how to produce the flat pattern from the helical piece. I have been trying to do this exact same thing in Onshape and struggled.
Lofted sheet metal still isn't currently supported by the Onshape sheet metal kernel. Surface Flatten is the closest thing at the moment until they unleash the lofts.
