trying to print text as separate color
Grompy989Grompy989 Member Posts: 18
i have a BBL CarbonX1 printer. i use Bambu labs studio to slice and print. how do it do multi colored prints from onshape? does it do 3mf file format? here is my design link. https://cad.onshape.com/documents/1b2334f64fdeab39273dd5fd/w/775f7a1924c3657b805385e8/e/d2052cb25bee05799d6925dc
what i want to do is have the text infilled so i can print it as a different color…The cap is black. the text is gray. but i want the text flush with the surface of the cap…does this make sense?
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hey @Grompy989,
    Have look at the link, I have recreated the model but instead of cutting away material I have created new bodies. You can just export all of the bodies in one .step export. Then you can assign different materials/colours to each of the bodies in Bambu Studio.
    https://cad.onshape.com/documents/d1fa7f47411ec91a096c0a2c/w/5d1e4d599eea6fb1cda655ba/e/188cad18245cdf29d08892a6
    You could also try to give this custom feature a go, seems a bit easier to create a new body that intersects with your part to do a boolean operation to remove material:
    https://cad.onshape.com/documents/4e187c2b2f7f4974f4e2b612/v/04e7ad76e7b3e4008b7632cc/e/8639f00c4f54af50704861a9
    Any questions, let me know.
