Referencing Array Parameter Index in Item Label Template
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
Is it possible to access and include the index of each array parameter in its label? Something like "Item label template" : "Line #index" ?
Do you agree? Can you think of a natural way of getting around the issue?
Another option would be to make array indices static, i.e. removing #2 does not renumber #3. The array indices could then be renumbered as part of the EditFeature function. I personally don't like this option. Skipped numbers would just get on my nerves. My brain would always think 1, 2, 4... wait, where's 3!?
Is there now a way to do this?
Thank you.
@graham_lock
editing logic and a UI hidden parameter can do it.
Thank you.
For anyone looking into this in the future - I've written a short blog article on the solution:
https://www.smartbenchsoftware.com/post/making-use-of-hidden-parameters-in-featurescript
