Best Windows Laptop Config for Onshape
Otto_DeRuntzOtto_DeRuntz Member Posts: 26 PRO
I'm up for a new laptop, what would you recommend for the ideal configuration for running Onshape?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,019 PRO
    For professional use, get at least 24GB of ram. It will make a difference for larger assemblies.
  • martin_kopplowmartin_kopplow Member Posts: 991 PRO
    Yes, and even though it is often said that super performant hardware is less important in an SAAS environment, and I agree with that, I have seen that a decent graphics card ist also worth something. The navigation is much smoother and fewer glitches with large assemblies. I'd consider that for a pro setup, not necessarily for hobby use.
    I have upgraded mine to 64GB RAM because I often run other programs in parallel and do not want my laptop to start swapping memory around while I work. Having is better than needing, and RAM is relatively cheap these days.
    The other component that speeds up CAD work is screen area. The larger the better. You'll probably want an external monitor anyway, I guess? Then the video chip, be it onboard or a video card, should support a decent one as well. And if it is a laptop, go for one that has a number pad, because that speeds up input of numerical values, which is frequently needed in CAD work.
  • MichaelPascoeMichaelPascoe Member Posts: 2,591 PRO
    Make sure it has a dedicated graphics card and some ram.
    Here are some real world benchmark results you can use to compare:
