Simulation
Kevin_Gallichan
Member, pcbaevp Posts: 6 PRO
Hi,
are there any instruction videos on the use of Onshape Simulation that are more technical and less sales orientated ?
Thanks
Have you taken this Learning Center course? https://learn.onshape.com/learn/course/introduction-to-onshape-simulation
Should be pretty technical and workflow-focused. Unless that's the one you found to be too salesy.
You can also go through the youtube playlist here:
Thanks for sharing.
Yes, I watched some of those, it's quite restrictive on what can be applied . My simulation failed. I copuldn't see how to figure out what was wrong, prbably soomething obvious but with no pointers as to what was wrong, I had to give up. Honestly none the wiser.
Exported the model to Solidworks Sim and was done in 15 mins.
I guess it's just a matter of trial and error, I shall have to persevere 😅
