When using Circular Pattern using Feature Pattern cannot hide used Sketch
Firstly, using Onshape for the first time and ABSOLUTELY LOVING IT. It is SO easy! I'm a 3D printing enthusiast and have struggled with Sketchup for years. Wish I had of discovered Onshape a long time ago!!!
Minor irritation that I cannot solve myself, just looking for some advice.
I have Circular Pattern using Features that I have replicated around a curved surface. When creating the original feature on the curved surface I had to create a sketch with a single construction line that is used as the pivot for a face move. Now when I implement the Circular Pattern using the Features for the Face Move around the Pivot line sketch, the Pivot sketch is replicated around the part and cannot be hidden. I can hide the original Pivot line sketch fine, but when I do, I would have expected the replicated sketches to also be hidden. I can't work out how to hide the replicated sketches. Any suggestions?
  • mark_sullivan
    mark_sullivan Member Posts: 2 ✭
    Hi Neil
    Thanks for the info.
    No I haven't assembled the part, this is just in part studio. Its good to know that in assembly the issue will not be evident.
    Yes I have to pattern with the sketch when using the Feature method, if I don't it doesn't work as intended
    I just changed the pattern to the Face method and you are correct that that it works as expected, and without the need to select the sketch.
    Thanks for the suggestions.
  • mike_craig020
    mike_craig020 Member Posts: 2 ✭
    I just ran into this issue. Any update on this since 2016 @NeilCooke?
