When using Circular Pattern using Feature Pattern cannot hide used Sketch
mark_sullivan
Member Posts: 2 ✭
Firstly, using Onshape for the first time and ABSOLUTELY LOVING IT. It is SO easy! I'm a 3D printing enthusiast and have struggled with Sketchup for years. Wish I had of discovered Onshape a long time ago!!!
Minor irritation that I cannot solve myself, just looking for some advice.
I have Circular Pattern using Features that I have replicated around a curved surface. When creating the original feature on the curved surface I had to create a sketch with a single construction line that is used as the pivot for a face move. Now when I implement the Circular Pattern using the Features for the Face Move around the Pivot line sketch, the Pivot sketch is replicated around the part and cannot be hidden. I can hide the original Pivot line sketch fine, but when I do, I would have expected the replicated sketches to also be hidden. I can't work out how to hide the replicated sketches. Any suggestions?
Hi Mark, this is a current limitation that will be addressed soon. Deriving or assembling the part will hide the patterned sketches.
Did you have to pattern the sketch? Often just patterning the feature will give you what you want. You could probably also have achieved the same result if you just used face pattern.Senior Director, Technical Services, EMEA5
Did you have to pattern the sketch? Often just patterning the feature will give you what you want. You could probably also have achieved the same result if you just used face pattern.Senior Director, Technical Services, EMEA5 -
Hi Neil
Thanks for the info.
No I haven't assembled the part, this is just in part studio. Its good to know that in assembly the issue will not be evident.
Yes I have to pattern with the sketch when using the Feature method, if I don't it doesn't work as intended
I just changed the pattern to the Face method and you are correct that that it works as expected, and without the need to select the sketch.
Thanks for the suggestions.0 -
I just ran into this issue. Any update on this since 2016 @NeilCooke?
