multi-part sketching techniques: Utilizing a master sketch: Exercise: Tail lights
lori_orrlori_orr Member Posts: 8
I cannot figure out step 8: adding ribs. I have the correct edges and parts and other settings as far as I can tell, but it wont generate. help?
  • robert_scott_jr_robert_scott_jr_ Member Posts: 747 ✭✭✭
    Hello. If hover your cursor over the title of the feature it will provide a message as to why the feature can't complete. What is the message? - Scotty
  • lori_orrlori_orr Member Posts: 8
    It says the rib did not generate properly. Selected profile did not produce a rib body. Make sure the rib alignment and direction are correct.
    Can you post a link to your document?
  • MDesignMDesign Member Posts: 1,297 PRO
    it looks like your shell is not applied or is on the opposite side. Maybe your rib sketch plane isn’t correct?
    yup shell was backwards! Thanks so much! I really rely on being able to see the full workspace window complete with viewcube and features and parts list. I don't know why they didn't include those in this tutorial.
