CAM Textures - wood effects in particular.
jonathan_stedmanjonathan_stedman Member, Mentor Posts: 73 PRO
Where would I look for a software or the the ability to add a wood texture onto a part that is the mould for a wood plank - approx 300mm x 1200. Is this possible in the CAM module .
  • Are there artificial wood cutting paths to get that effect?
  • The texture could be a jpg image that is converted using contrasting heights and then exported as a surface
  • Or do I scan a plank with a hand held scanner and import that into a partstudio as a surface
Open to suggestions on route to investigate
Regards
