CAM Textures - wood effects in particular.
jonathan_stedmanjonathan_stedman Member, Mentor Posts: 73 PRO
Where would I look for a software or the the ability to add a wood texture onto a part that is the mould for a wood plank - approx 300mm x 1200. Is this possible in the CAM module .
  • Are there artificial wood cutting paths to get that effect?
  • The texture could be a jpg image that is converted using contrasting heights and then exported as a surface
  • Or do I scan a plank with a hand held scanner and import that into a partstudio as a surface
Open to suggestions on route to investigate
Regards
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,643 PRO
    There is a "wood grain" custom feature that might be able to help?
    It just produces surface splits but you should be able to use it as a base to add some cut features to your faces.
    https://cad.onshape.com/documents/f5cd9f4b2ec8e9eea7266f1e/v/7b36726274b62ee2f6b6f979/e/4626b80fb148952bd0b75c92
  • jonathan_stedmanjonathan_stedman Member, Mentor Posts: 73 PRO
    Thanks for the pointer - I'll look at that.
    Also found this Feature script from CADSharp - may give them a call about how to adaptor commission it to my specific needs.
    https://www.cadsharp.com/featurescripts/
  • MichaelPascoeMichaelPascoe Member Posts: 2,821 PRO
    Hey @jonathan_stedman I assume your referring to the Texture feature. It already has wood grain example built into it, however you can also make your own texture templates with any pattern you like and use those. I'll DM you for any custom work if you need more than what the feature can already provide.
    RENDERCAD
    Michael - Thanks for getting in touch. I'll take a look at it in more detail on Thursday. Just doing some preliminary research for an element of a project that is in its infancy so don't want to waste people's time too much. If you can DM me your email. Presume your US based. I'm in the UK.
