ChatGPT Atlas for FeatureScript vibe coding
S1monS1mon Member Posts: 3,870 PRO
OpenAI has introduced ChatGPT Atlas, which is their own web browser with built in ChatGPT agent functionality. So far this is MacOS only, but Windows is in development.
https://openai.com/index/introducing-chatgpt-atlas/
What this means potentially is that you can use ChatGPT to vibe code FeatureScript. So far I'm not getting any particularly exciting results, but I'm not giving it the easiest problem. It does have the ability to edit the code within the FeatureScript tab of an Onshape document. It will hit the Commit button for you if you want. Again, I'm just starting, but it does seem like we're heading in the right direction.
