ChatGPT Atlas for FeatureScript vibe coding
S1mon
Member Posts: 3,740 PRO
OpenAI has introduced ChatGPT Atlas, which is their own web browser with built in ChatGPT agent functionality. So far this is MacOS only, but Windows is in development.
https://openai.com/index/introducing-chatgpt-atlas/
What this means potentially is that you can use ChatGPT to vibe code FeatureScript. So far I'm not getting any particularly exciting results, but I'm not giving it the easiest problem. It does have the ability to edit the code within the FeatureScript tab of an Onshape document. It will hit the Commit button for you if you want. Again, I'm just starting, but it does seem like we're heading in the right direction.
I'll give it a shot and see if it can dethrone Codex from my vibe coding toolbag. Codex did just get a quantization nerf that I'm not happy with working around lately so it might not take much.
Derek Van Allen | Engineering Consultant | MeddlerCan ChatGPT Atlas use two browser tabs at the same time?
Then it could code in one, commit the FeatureScript and check the result in the PartStudio.
I'll have to test as well
