Penpocket
nicklas_fredriksson416
Member Posts: 3 ✭
in General
Hello,
I´m new to this program and new at CAD-program. Started with crafting in lether. And I want to do a CAD drawing on me on design on a Pennpocket
Can anyone give me anvicee witch tutorials to start with to learn to do one of theese designs. The hole design with stitch line and all
// Nicklas
Start with the basics at learn.onshape.com
If you're modeling it flat should be doable with the basics under your belt.
If you're modeling it as if packed with pens. you will have to expand your knowledge/skillset from the basics into lofts or maybe even surface modeling.
It may make sense to use the sheet metal tools to model the folded part.
