Penpocket
Hello,
I´m new to this program and new at CAD-program. Started with crafting in lether. And I want to do a CAD drawing on me on design on a Pennpocket
Can anyone give me anvicee witch tutorials to start with to learn to do one of theese designs. The hole design with stitch line and all
// Nicklas
  • MDesignMDesign Member Posts: 1,289 PRO
    Start with the basics at learn.onshape.com
    If you're modeling it flat should be doable with the basics under your belt.
    If you're modeling it as if packed with pens. you will have to expand your knowledge/skillset from the basics into lofts or maybe even surface modeling.
  • S1monS1mon Member Posts: 3,957 PRO
    It may make sense to use the sheet metal tools to model the folded part.
