Challenges App - Multi Step
ron_sauerron_sauer Member Posts: 4
I recently came across the Challenges App in OnShape and am enjoying it. However while doing my first multi-step challenge I ran into a problem.
After completing the first step of the challenge successfully I moved on to step2. While working step 2 I was logged out somehow and needed to log back into OnShape. However, upon logging back OnShape doesn't recogize that I already completed step 1. It wants me to start over from an empty Part Studio. OnShape recognizes that I have completed other challenges but not this intermediate step within a challenge.
Am I missing something? Do challenges need to be completed in one uninterupted session?
Thanks in advance.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 949 PRO
    One of the coolest things about Onshape is that is remembers every change you make in a document, so if your computer melts or your connection dies, your data is safe. At this time, CAD Challenges does not possess the same level of data persistence. Data is only saved on final submit.
  • ron_sauerron_sauer Member Posts: 4
    Thanks for the reply.
    I was surprised that my progress wasn't saved precisely because OnShape remembers everything.
    I'll take that into consideration before starting a challenge.
