Anyone have an FS that can convert a decimal length to a (reduced) fractional equivalent
eric_pesty
Member Posts: 2,396 PRO
I know people in the metric (most of) world are going to be like "huh?" but I'm trying to match a convention to build a part description parametrically…
I was hoping Pascoe's "variable to string" FS would do it but it doesn't include that function, which tells me it's not super trivial so I thought I would ask if anyone has some code I can (respectfully!) "steal" before I go on a coding adventure!
The stack overflow thread on the topic is somewhat helpful resource if you want an "optimal" answer
https://stackoverflow.com/questions/5124743/algorithm-for-simplifying-decimal-to-fractions
Its not a trivial problem, but its a simpler problem if you are constrained to not just any fractions, but typical base 2 fractions ( 1/4, 1/8, 1/16 , etc)
You could find the closest /32 fraction (or 64 or 128) and then find the highest common factor
Thanks @Caden_Armstrong ,
Ended up writing something with some help from ChatGPT (for the algorithm part)…
Seems to work and looks like this if anyone is wondering:
FeatureScript 2780; import(path : "onshape/std/common.fs", version : "2780.0"); annotation { "Feature Type Name" : "Decimal to Fraction", "Feature Type Description" : "Convert a decimal length to a fraction string" } export const DectoFrac = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Decimal Length" } isLength(definition.decLength, LENGTH_BOUNDS); annotation { "Name" : "Smallerst Denom, eg: 16 for 1/16", "UIHint" : UIHint.REMEMBER_PREVIOUS_VALUE } isInteger(definition.precision, POSITIVE_COUNT_BOUNDS); annotation { "Name" : "Variable Name" } definition.varName is string; } { const decValue = definition.decLength/inch; const precision = definition.precision; var whole=floor(decValue); var frac = decValue - whole; var denominator= precision; var numerator = round(frac * denominator); println(whole~" "~numerator~" / "~denominator); if (numerator !=0) { var a=numerator; var b=denominator; var r=1; while (b!=0) { r=a%b; a=b; b=r; } var GCD=a; println(GCD); numerator= floor(numerator/GCD); denominator = floor (denominator/GCD); } else { denominator=1; } if (numerator==denominator) { whole += 1; numerator=0; } /* println(whole); println(numerator); println(denominator); */ var theString; if (whole==0) { theString=numerator~"/"~denominator; } else { theString=whole~"-"~numerator~"/"~denominator; } setVariable(context, definition.varName, theString); // Define the function's action });
