Two blades don't revolve together
john_torjohn_tor Member Posts: 10
Hi everyone,
I put the yellow pivot between the two blu blades of a lamp model:
According to the tutorial I was watching, the two blue blades were supposed to revolve together this way. However, as you can see in the image below they don't.
What did I get wrong?
here is the link to my project
Thanks
  • robert_scott_jr_robert_scott_jr_ Member Posts: 657 ✭✭✭
    Hello John. Couldn't get the link to function. The two arms need to be fastened to each other. I don't know what the tutorial's instructions are, but I would guess that the pivot is supposed to be fastened to both arms. - Scotty
  • john_torjohn_tor Member Posts: 10
    I don't know why the link didn't show up.
    here is the link (I hope):
    https://cad.onshape.com/documents/39157911ec9bedfd8b1d84fe/w/ed9db64a5e4d7d3d7d34edb6/e/1be34e91c80dcd85c7bd5226
    John, looks like you've got it working correctly via the Group feature. Correct? - Scotty
    Meanwhile, just to go ahead with the tutorial, I grouped the two parts. However I don't know whether it is the right move.
    Thanks
    Yes I did, Scott. But I'm not sure if it was the right way to do that. Furthermore, the tutorial don't meantion the Group feature though. It seems that the revolve just works for both by placing the yellow part between the blue ones.
    Thanks
