Converting to Sheet Metal Part
aj_grahamaj_graham Member Posts: 4
I have a model that I am looking to transfer over from Fusion to Onshape. In general I like the CAD workflow far better over here. I am running into a couple problems with some of the parts though. Specifically ones designed to be made out of sheet metal. In this example I am trying to import a simple bracket that is designed to go between two parts and has a few countersunk holes in it. In Fusion I would be able to convert this bracket to a sheet metal part that can then be unfolded to create a drawing of the pre-bent part.
However now matter what I seem to do I am unable to get this part to convert. I have tried with and without bend radiuses, multiple settings, ect. One thing I have noticed is that the holes are often highlighted in red. Am I unable to convert a part to sheet metal if it already has holes in it? I am trying to avoid having to redesign all sheet metal parts in my design during the transfer.
Any help is appriciated!
https://cad.onshape.com/documents/000e70600f2dcbfe55cb3b66/w/6cbee1d5b786173800c53ad2/e/6165e6250fd40bc75f620609?renderMode=0&uiState=6903f31bd5c21d0d59b2a798
