Mind maping Onshape's CadBOM
Hi,
I want to do a mind map of my CAD as it's getting pretty complex. I want to include the studios, the parts and assemblies and where they came from : imported or created in onshape, from the current document or anotehr one, and all the links between parts: is it created from a context (which one), does it use derived geometries (from where), is it using a variable table, … You get the idea.
Onshape files can be structured from an assembly and it's pretty good but i'm lacking informations (many the links).
So here is my question : can I access (and export) those CAD informations to make a map of all the links of my project ?
(Here is the current mind map I'm using, I want to upgrade to a dynamic and auto-filling mind map. Excuse the French in the screenshots :)
I'm open to any idea, exporting and doing it with a Data Base, with a linked app or whatever.
Tanks !
  • martin_kopplowmartin_kopplow Member Posts: 1,319 PRO
    That is in fact a valid idea. I've een thinking along a similar line recently, when I was in the process of explaining a partner how the model is structured. I even believe it would be a good thing to have a visualization like this living in it's own tab all the time.
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 304 PRO
    edited November 2025
    There was an App called OneIPM that did something like that, unfortunately they were acquired by Autodesk so that is ☠️
    CAD Engineering Manager
  • Caden_ArmstrongCaden_Armstrong Member Posts: 413 PRO
    From an API/External App perspective, you can get all of the information that you need from a single bill of materials call.
    The BOM visible in Onshape doesn't have all that link information, but the API has access to it.
    For example:
    https://cad.onshape.com/api/assemblies/d/4833676df7d2a808ac4b52b7/w/1779c4496f69618947b539b5/e/75f2654cbbb785c3812333d2/bom?multiLevel=true
    Out of curiosity, how do you use the mindmap? What information are you getting out of it?
  • wayne_sauderwayne_sauder Member, csevp Posts: 651 PRO
    What did Autodesk want out of OneIPM, an onshape app???
  • Philemon_BoucartPhilemon_Boucart Member Posts: 11 PRO
    Autodesk seems good for this kind of features: it would in fact not be so complicated to code a map if i could access a text file of the parts but Onshape doesn't have DXF or DWG exports for 3D.
    Maybe autodesk acquired it because it's an easy match for their file format?
    Okay Thanks! I will see if their is all the information i need and if i can do something out of it.
    I mainly need it for collaboration purposes. I am an internee and i did the migration of the main product of the company i work for from Fusion to Onshape. I tried to make it a robust product with a top-down conception. So a mind map would be great for the people to know what i did and what's possible to do without making the conception weaker. A map is a cool visual tool, in Cad if a part has two different inputs our if there are too many layers of input, it begins to be tricky. With a map, it can be detected and avoided.
    Basically i'm trying to get people to understand my work and not destroy it as soon as my internsheep ends :)
    How did you get the example you sent?
    i went to the glasswork explorer but i haven't find a BOM related info
    https://cad.onshape.com/glassworks/explorer/#/Assembly/getBillOfMaterials
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 858 PRO
    @Caden_Armstrong is there an API call that can search through a chain of derives? I do have a use case where it could be helpful to view the tree of a bundle of derive features that are passing info from studio to studio. A near sister case to the original question for bill of materials.
