Best method for creating bevel gears?
jillian_oglejillian_ogle Member Posts: 3
Not sure how to actually bevel the gear accurately as needed...
    Yikes. That's a fairly difficult modelling challenge (and a machining one, too, for those lacking dedicated gearcutting machinery)
    Assuming you want the geometry to be suitable for actual working gears:
    You would need to bone up on the involute geometry of an individual toothspace, then recreate it on a suitable sketch plane, then loft a solid body from that sketch to a single point at the intersection of the shaft axes. Then circular pattern the body, and subtract the resulting bodies from the solid representing the blank (deselecting "Keep Tools") using a Boolean operation.
    If you're after a visual representation only, you can cheat by simplifying the toothspace profile.
    Nice exposition, @isaku_kamada - Just one thing for people to be aware of if trying to construct accurate involutes for bevel gears: if using tabulated data, people need to bear in mind that the involute profile lies normal to the pitch cone (a notional cone roughly half way up the teeth). I'm sure isaku took this into account but it may not be obvious to those reading the method.
    The person wishing to build an accurate model will have to specify the angle for this tilted plane (mentioned by isaku) taking the pitch cone angle into account.
    For meshing with existing bevel gears, or if the ratio of the pair is not 1:1, it is also crucial where that profile is located along the cone (these are the sorts of details which I had in mind when referring to it as "fairly difficult").
  • jillian_oglejillian_ogle Member Posts: 3
    Wow guys, thanks for the super thorough answer! This is amazing! Totally helpful. I never had someone give me a visual step by step tutorial on a forum question before. A+++
    To clarify my earlier post and eliminate confusion with other recommendations: step 2 of isaku's method should be slightly amended:
    the line for the loft should be within the body of the gear blank, on the pitch cone (whose included angle can be calculated from bevel gear formulae).
    Then in step 3, make sure the plane he refers to is positioned normal to this amended line.
  • isaku_kamadaisaku_kamada Member Posts: 2
    @andrew_troup, thanks for the clarification comments! :)
    Is there a good place online anyone knows to get some pre-made gears that can be edited in OnShape?
    edited August 2015
    @jillian_ogle Stock Drive Products would be my pick... http://www.sdp-si.com/
    http://www.sdp-si.com/eStore/CoverPg/Gears.htm
    http://www.sdp-si.com/eStore/Catalog
  • michael3424michael3424 Member Posts: 736 ✭✭✭✭
    I think that WM Berg also supplies models of the gears that they sell.
    http://precisionparts.wmberg.com/gears
    Misumi supply 3D models  of bevel gears -- not a huge range (small sizes range, in particular, but you can easily scale them up)
    http://us.misumi-ec.com/vona2/detail/110300429650/?Inch=0&CategorySpec=00000029849::a
    They do supply any item from their range on very short timeframes and generally remarkably affordably, all things considered.
    Rush gear has a good selection and you can create you own spur and helical gears.
    You can Download the models.
  • elonas_radzeviciuselonas_radzevicius Member Posts: 2
    For standard (and not so very) parts you may simply go to:
    www.traceparts.com
    www.partcommunity.com
  • nicolas_7nicolas_7 Member Posts: 8 ✭✭
    it's even worse than that, for bevel gear we don't use involute, but an octoid tooth profile: https://en.wikipedia.org/wiki/Bevel_gear#Geometry_of_a_Bevel_Gear
