.... How do I 'Mate' RHS 50 x25 Pieces
Have just started with OnShape and Still 'Stupid' …..I am Trying to Create a Frame for CNC Router …. 50 x25 x 2 RHS… Having an External 3mm Radius …. How do I find the Correct 'Mate' surfaces as there are no True Fastened Mating Surfaces ….. I am Retired, so all Very New to me …. :-) :-) :-)
Many Thanks ….
Keith Brinch
  • robert_scott_jr_robert_scott_jr_ Member Posts: 824 ✭✭✭
    Hey Keith. Welcome to Onshape. I'm guessing you mean that since the pieces are hollow a mate connector won't be available at the center of a piece's end. While selecting a point to place a mate connector on an end, when Onshape 'wakes up' locations to place the connector, hold down the shift key which tells Onshape to 'stay on this plane' and you can then move your cursor to the center which will 'wake up' a connector there. - Scotty
  • keith_brinchkeith_brinch Member Posts: 4
    Thanks for your Reply …. After MUCH Searching on YouTube …. I actually got it to work, Perfectly ….. BUT it WAS Quite a hassle as Each 'Connection ' took 3 " Planer " Faces to pull things together …. I am sure that there is a Far Better and Easier way …. I found that using "OnShape" was a Lot more Intuitive that Other ones out there …. I used to 'Play Around' with AutoCAD LT and the 'Methods' are 'Similar …..
    Thanks to All … Much appreciate All the Great Support to a 'Newbie' to OnShape …. ( Although being 74 Already …. :-) :-) :-) )
    Wishes from Christchurch, New Zealand
