NEW Video series: Expressions in Onshape
Onshape does a good job at blurring the lines between CAD and code without being overwhelming for beginners. One way this happens is by allowing access to FeatureScript functions in any input field. In this series I'm covering pretty much everything I know about it from basic to advanced. Videos 1 and 2 are out now with another 4 or so on the way.
Part 1: Math and Units
Part 2: Number manipulation
9
Will have to watch! Thanks for putting this together.
Dope!
This is a much needed topic. Opens up so many possibilities. Nice job Evan!
pt 3 just dropped covering true/false and if/then
Part 3: Boolean Logic
Thank you, for a non-coder this is really useful.
I'm trying to trick non-coders into coding without realizing it 🤫
Well its working!!!
Love this mentality and it makes so much sense with what you mentioned at the end of video three, how Onshape is also tricking us all to code by using a CAD system. I 100% agree that the sooner people realize this the sooner they can become a CAD magician.
chadstoltzfus@premiercb.com
Part 4: Containers is now live
I just watched #4 (at 2x).
These are great. I know that things like this can be done, in theory, but seeing actual applications and examples is really powerful.
Thanks, Simon! I think I didn't do maps justice here, but might add a bonus in the next one if I can think of a good case to show.
Maps are a bit weird. I understand some of their uses in FeatureScript, but as an end user I'm not as sure where they would come into play, other than perhaps some sort of configuration tool.
if they'd autocomplete with their keys as you type they'd immediately become more useful as a way to group related variables. That's the one thing keeping me from using them that way.
Maps are important for "object oriented programming", or just structured data. Data doesn't just exist, but the value belongs to something.
In the context of just the feature tree (no featurescript) generating the data is probably the hindrance to it being useful. But knowing how to reference the data might useful if you were to have a FeatureScript generate the data.
For example, if you had a featurescript generate a series of objects (lets say boxes). Each has a property, length,width,height. As named variables, for N boxes, you'd have to create each variable and give it a unique name, like "Height_1", "Height_2". Which doesn't seem bad until you see downstream effects.
But if you created a variable that had an array of maps - where each map has the properties of that specific box. The properties of each box could be easily indexed and referenced.
box[ i ].height is a lot easier and more flexible than trying to reference "Height_i". The height of the ith box could be an input, but the indexed box could be configured, and its infinitely scalable.
In fact individual part studio variables are already equivalent of key-value pairs in the map. The map is only required if you need to dynamically add or remove keys, or ensure key uniqueness. Also in some cases it is handy to check equality on maps since they not depending on order, but thats unlikely to be used for normal modeling
Yep, great clarity. You're both hitting on why I struggle to come up with a believable use-case that doesn't require any "real" featurescript coding. When coding an actual feature they're indispensable, of course.
I really would use it in Variable features like this though though if it autocompleted the contents, just as a way to organize my variables better. It could be used to create something resembling a file path so you could drill down to the right variable without being hit by all variables at once for autocomplete options. I use a lot of variables.
For now all I've got is "you can do this! neat right? Any idea what you'd do with it?"
Just dropped part 5 which deep dives into functions.
Sweeet!
I bet you can now use more terse function syntax: () ⇒...
Ooh I'll have to try that! Thanks
Last part just dropped where I explore a bunch of the odd "i'm not sure how I'd use this, but it's interesting" things I've discovered about expressions in Onshape fields. We get very weird with it with things like in-line comments, phone number format validation, and even good ol' println() functions.
@EvanReese thanks so much for this series! This helped me rethink Onshape in some very key ways. More importantly, kickstarted my journey into Featurescript, which I think was secretly the whole goal of your series.
The culmination to this is that I ended up creating my own version of tweened creases on a curved surface and also another version that wraps around the perimeter of a box.
woah nice texturing! I'd love to see the workflow. I've done similar things with a workflow involving query variables and a yet-to-be-released custom feature. It'll be in a video soonish.
Your LinkedIn post, plus @Derek_Van_Allen_BD's Tween curve feature, heavily inspired this. From there, I think I happened upon your * redacted * document (By happenstance. I'm not sure if it was meant to be public or not). It's honestly a pretty similar workflow, but I'm using Loft instead of Fill to set some tangency constraints. I did create a custom script to make arc profiles. It's not the cleanest code, but then again, I'm not a real programmer.
If you wanted to take a look (and tell me what I should improve), here's the link:
https://cad.onshape.com/documents/fe37596d524943d8cba7250b/w/21831fff4d8f1017e9e72e6c/e/247e80761e0ed8f98ae8e8a1
I'm just glad that anyone is getting mileage out of the tween curve feature. I had it in my backlog to implement a multi-tween feature at some point but got sidetracked by the depths of the rabbit hole that tween curve ripped open underneath me from its intended use case.
Derek Van Allen | Engineering Consultant | Meddler@ry_gb 🤫
It's been redacted!
Honestly, I'm just glad you laid the foundation for it. Thanks for doing the real heavy lifting. I'm hoping to see what else you do with it, so I can retire mine.
Too late! I've seen everything.
Derek Van Allen | Engineering Consultant | MeddlerWoah! Now this one I didn't see.
🚨SYSTEM BREACH🚨… 🚨SYSTEM BREACH🚨… 🚨SYSTEM BREACH🚨
