combined rotational and linear movement
chris_butcher076chris_butcher076 Member Posts: 10
I have just modelled a TriviThick Loco, and am quite happy with the animation of loco itself, now I would like to run it on a track. I have set a test assembly just with the track and carriage, applied a 'tangent' constraint between a wheel and the track, but ended up with rotational movement of the carriage still, so I applied a 'parallel' constraint between the carriage and track. In the past I have completed a tutorial somewhere of a model with wheel running on a track (board) using Tangent and Planar constraints but I can't get it to work here. Any help much appreciated.
https://cad.onshape.com/documents/00fdd4b88d4b367dd2402bee/w/cd3aca8bfcaaadf382ad5a9c/e/88e9fd716a07bac0fe34670d
