Custom Automatic Numbering Schemes
Mark_DaavettilaMark_Daavettila Member Posts: 3 PRO
Our company is an OEM of large process lines. These consist of a series of unique stations. Our current part numbering scheme looks like this xxxx-yy-zzz. Where xxxx is a 4 digit number identifying the project. yy is a 2 digit number identifying a station on that line. and zzz would be a three digit unique identifier for each component of that station. At times we will add a letter to the end of the PN to further identify it as a sub assembly or weldment component. For example a PN of 1234-56-789A would immediately identify this part as a component of sub assembly 789, on station 56, for project 1234. This numbering system has worked very well for us to quickly identify and categorize parts.
We are in the process of switching from a different CAD software which had a built in PDM software which did not allow for duplicate part numbers. But we have not yet been able to find a way to utilize the built in Onshape numbering schemes to work for our numbering system. Instead we resort to manual entry for each individual part number inside of a parts properties. Which has no safeguards against duplicate part numbers, and opens us up to errors in the manual entry process for typos etc.
Does anyone have a workaround or fix for this issue, is there a way to further customize the Onshape automatic part numbering scheme?
Any help would be appreciated.
  • rafael_bovarafael_bova Member Posts: 1 ✭✭
    edited November 2025
    Hi Mark,
    I’ve been tracking this feature request for quite some time now, but I don’t believe it’s a priority for the Onshape team. The reason is likely because there are apps in their marketplace that assist with this custom part number issue. The best one is OpenBom, which allows you to create more robust custom IDs.
    OpenBom PartID docs: https://help.openbom.com/get-started/part-number-management/
    OpenBOM Tutorial: https://www.youtube.com/watch?v=hy71kt0mdCo
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hello @Mark_Daavettila,
    Have a look at this document and the approach to project specific part numbers: https://cad.onshape.com/documents/66526c93213769e26ebe04ec/w/9b7b5354aa20b7aa5e5dcd6d/e/9a536a0a42d57284590ff773
    This uses a custom feature which you can easily adjust to your needs (project number/station/etc.). You will still use Onshape's automatic number generator and therefore make sure there won't ever be any duplicate numbers. One possible limitation is that you won't be able to reset the part number for each project but that the number will continue.
    Hope this helps. Cheers
