Improvements to Onshape - November 21, 2025
This update brings new CAD and Simulation tools, multiple improvements to Drawings, new appearance options for Render Studio Advanced, and expanded collaboration with Onshape Enterprise users with the all new Slack connection!
CAD
DYNAMIC SUPPRESSION
Create logical expressions to determine when a feature should be suppressed or unsuppressed. Dynamic suppression can also be used in configurations.
ANGULAR VELOCITY LOAD (CENTRIFUGAL LOAD)
Support for applying Angular velocity loads in Simulation, enabling centrifugal force analysis on rotating components.
SHOW MAX/MIN SIMULATION VALUES
Simulation plots for Linear static simulations can now highlight maximum and minimum result values directly on the model for faster interpretation.
GRAPHICS PREFERENCES
New Graphics preferences in the Camera and render options menu let you set line width, shininess, specular color, and field of view. These options are especially useful for surface modeling. Preferences persist across all documents and can be reset to their default values.
LEVEL OF DETAIL IMPROVEMENTS TO GRAPHICS
If the level of detail of a part at a specific zoom level requires representation at a higher level of detail, and that higher level of detail is not available, it will be generated on demand, resulting in improved graphics without a reduction in performance.
DRAWINGS
VIEW ROTATION AND ALIGNMENT CHANGES
The Rotate view functionality has been moved to a right-click submenu where users can specify horizontal or vertical rotation by selecting geometry from the view. A new Align views option allows users to align views to one another through a right-click menu, with the ability to specify vertical or horizontal alignment.
DRIVING DIMENSIONS SUPPORT FOR TOLERANCE, PRECISION, AND OTHER PROPERTIES
Driving dimensions in Drawings now support custom decimal precision, tolerances, and Format painter formatting for faster, consistent detailing.
SKETCHER INFERENCING
Sketching in drawings now includes inferencing to help align and snap geometry more accurately.
DATA MANAGEMENT
WARNING WHEN DRAWINGS REUSE INSTANCE PART NUMBER AND ONLY ONE IS SELECTED FOR OBSOLETION
A warning is displayed when only one of several items sharing the same reused part number is marked obsolete. The items must also be created as part of the same Release candidate in order for this notification to appear when creating the Obsolete candidate.
COLLABORATION
SLACK INTEGRATION FOR ONSHAPE ENTERPRISE
Slack integration with Onshape Enterprise allows for Release candidates, Tasks, and Comments to be bi-directionally shared, so information flows to where team members work. Slack commands can be used to view the top 20 most recent documents and the top 10 most recent task lists directly from Slack.
RENDER STUDIO
AXF APPEARANCES FOR RENDER STUDIO ADVANCED
Adds support for AxF measured materials, enabling physically accurate scanned appearances to be applied to Render Studio models.
NAVIGATION SPEED IMPROVEMENTS
Improved pan, zoom, and rotate performance in Render Studio, especially in scenes containing a large number of instances (1000's).
MOBILE
SNAP CAD TO REAL GEOMETRY IN AR VIEW
AR View now supports snapping CAD geometry to real-world features to improve alignment when overlaying designs on physical objects.
LEARNING CENTER IMPROVEMENTS
INTRODUCTION TO ONSHAPE ASSEMBLIES
The Learning Center now features the Introduction to Onshape Assemblies course where you can master the essentials of Onshape Assemblies. Explore the Onshape mates that bring assemblies to life by defining their degrees of freedom. Discover how to easily position and adjust assembly components with the intuitive triad manipulator. Reinforce your knowledge through hands-on exercises that help you master positioning, mating, and structuring assemblies.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update. Mobile app interface updates occur via the Apple App store or Google Play store and happen in the days following the update.
Dynamic suppression is gonna come in real handy. Been waiting for that for awhile. It's on the list with dynamic ranges for configuration variables.
2 -
Dynamic Suppression and all the drawing improvements look great!
2 -
Dynamic suppression is going to open up some interesting workflows. You can set suppression using a variable, which means that you can use up stream features to control down stream features. Like a measured variable output could control the suppression of a later feature.
www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications1 -
Dynamic suppression multiplies the power of Onshape configurations - very exciting.
I can check this myself, but does view alignment work between views that are technically unrelated - like two different parts or configs of a part, or a part and an assembly?
Slack integration is great. More integrations like this (Google Chat, MS Teams, etc.) will be necessary to hit the majority of potential companies out there, but Slack is probably the best place to start.
Graphics preferences solves some issues which have been frustrating for many many years. Hopefully being able to make some lines super lightweight will also go into drawing mode at some point. The lower limit there is artificially too thick for my tastes.
Interesting to see angular velocity re-appear. I know it was introduced recently, but it magically got pulled and now it's back.
Rendering, drawing constraints, and view improvements are very welcome.
In the change log, there's this item: "New Explore Onshape (Free, Trial and Discovery plans)". I did some digging on the web site and can't figure out what's new here.
1 -
Would it be possible to add a "Save Preset" option for the Graphical Preferences? Great update, love the dynamic suppressions!
4 -
DYNAMIC SUPPRESSION…. This is a big one for us.
Thankyou0 -
In playing around with the new Graphics Preferences, some observations:
If you have tangent lines set to phantom, the line width control doesn't do anything, which is frustrating (a bug in my mind). With the regular "tangent edges visible" set, the line width affects the tangent edges.
If you really want to kill the specular highlights, set the "shininess" to 1% AND set the highlight color to something dark. With some subtle tweaks of the highlight color you can get some really nice soft smooth lighting.
I'd really love to see some better materials and realtime HDRI lighting in the browser without needing to resort to Render Studio. I know this is possible. Here's a link to a share of a Plasticity model.
I'm very happy to finally be able to set FOV in Onshape. This improvement request from 2015 can finally be retired.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
2 -
All of these updates look solid and I can't wait to try them out. Dynamic Suppression looks amazing, and I'm happy to see some of the interesting graphics controls. I can seen Onshape progressively becoming a very solid technical illustration tool. With a few small wrapping features, things like assembly instruction illustrations and sequences are within easy reach. Couple this with the cloud architecture, publications, etc. and we're very quickly opening up a whole new domain of use cases.
2 -
The change log also shows, "Support import of PVZ files". This one is a big deal for me! Thank you Onshape!
I'm testing it now.
You spoil us. The improvements to tellesation and graphics are huge. Thanks for another great update!
The next step would be to integrate the shininess and specular color into appearances, and add features like roughness. Super basic on the fly rendering within part studios and assemblies would really help with some of the industrial design work I do.
Thanks again.
2 -
Dynamic suppression is a game changer, so excited about it!
she/her
Thanks for the feedback and suggestions (as always) @S1mon - we've been looking forward to expanding some of the possibilities regarding graphics. It remains a focus…
And if by "something dark" you mean#000000then yes that's the ultimate specular highlight killer :)1 -
@GregBrown In this case, I was alluding to grays that are close to black, but with a slight warm or cool caste depending on the colors of the model. I did try Black #000000, but that, as you say completely kills the highlights. I'm sure that there are cases where that would be helpful.
If my wife wasn't sleeping, and I mean this from the bottom of my heart, I would have SCREAMED out my chest in excitement over Dynamic suppression !!!!! I have wanted this since month 1 of using onshape, and it has been at the top of my list since.
Onshape team holy mother of God! I love you! Marry Me!9 -
dynamic suppression just make configuration even better, great update.
2 -
Dynamic suppression and field of view are two I've wanted for a long time and they both look like great implementations!
4 -
Hi there, Where is a link to LEARNING CENTER IMPROVEMENTS >
INTRODUCTION TO ONSHAPE ASSEMBLIES?0 -
Yeah I'm not sure what "shininess" is supposed to mean in this case…
It sort of makes sense if it's the opposite of roughness where more shiny means more a "point" reflection, but it also seems to get brighter at low values, which doesn't make sense…
Maybe it's a combined slider that cranks up the brightness as the the reflection gets more diffuse?
I think I like it best at really low value but with a dark highlight (like a 444444)3 -
@troy_ostrander Hi, thanks for that, here is a link to the course in the . I have updated the post as well.
Regards,Mike LaFleche @mlaflecheCAD0 -
Dynamic suppression is extremely long anticipated by me. 🤗 I'm hoping dynamic suppression in assemblies is just around the corner. 🤔
1 -
Agreed there a number of different ways to describe what is going on, and the argument for/against each does start to get wrapped up in the practical versus science behind them. @eric_pesty you did kind of hit on it with the comment about "point reflection" - the light source which we are using plays directly into it. Describing it using terms like "roughness" or "polished" or "scatter" might each have merits, and of course we reserve the right to make things better, especially if we ever decide to provide more controls.
And @eric_pesty 's last line is important:I think I like it best at really low value but with a dark highlight (like a 444444)These are your preferences and everyone is right! (I'm on Team Shiny #EAEAEA, 70%, 2px line)
3 -
I think I found an slight issue with the graphic control change. Setting the line width to minimum makes it difficult to select edges at times. Turning it up to max and not spinning the model allows me to select the edge no problem. I'm doing it with fillet but I'm guessing its an issue in general.
1 -
@robert_stiles @shawn_crocker Thanks for your early feedback on dynamic suppression! — hopefully you can see how some of your suggestions have been incorporated.
@christopher_dziuba I have discussed your proposal with the team and in the spirit of putting the customer first, we've decided to accept. But just to double-check before we start planning the wedding, how many mothers-in-law would you be comfortable with? 🙃
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc11 -
I now understand the shininess scale being different than expected. Thank you @eric_pesty &. @GregBrown I think the term Shiny while catchy may not be the best choice as it implies a very different meaning when your not loooking at a "true" surface reflection and only a single sorta representation of a reflection. Its a set it once and forget it type of thing, no big deal.. Would love to have one more tweak to it and that would be either the intensity and/or the color of that point source.
1 -
I edited my edge selection comment to include context motion gif.. It seems somewhat related to the orientation of the edge and what else is around it to select.
1 -
@ilya_baran 23 mothers in law, but first lets colab and see where this "relashonshape" goes
8 -
Dynamic supression is awesome! I noticed it can be set for a folder of features as well, although beware that it doesn't update to features being removed/added to that folder… That may be a small improvement?
I'm also excited about trying out the Graphics preferences!0 -
- Dynamic suppression is a big deal! One more thing I can remove from our custom features.
- Graphics preferences!! Literally just opened a ticket about a line thickness issue. This solves it beautifully!
- Sweet LOD and drawing improvements too.
- Woah, AR View snapping is pretty cool! Could definitely find some uses for this.
Always appreciate these Render Studio improvements.
Now just pop that image into RenderCAD and presto😎
▚▞▚▞▚▞▚▞▚2
