Projects for Teachers in the Learning Center
Matt_Shields
Member, Onshape Employees Posts: 934 PRO
In the Learning Center, under Educator Resources, you'll now find a category called Projects. These are full projects to inspire teachers and excite students. Each project includes learning objectives and sample Onshape documents, along with additional recommendations for pacing, extensions, and more. Check them out. Comment in this thread if you have questions and please share if you've tried one of them!
3
Hi,
I would like to implement the Bike Frame Design Challenge to my class, but Onshape Simulation features are only found in the Professional version. Is that correct? Please instruct.
Thank you,
Eduardo Barraza
If you have an education account (even the free one) you have access to the simulation features. You can find them in an assembly.
As you can see here:
https://www.onshape.com/en/education/plans
Simulation is included in the Educator Plan. Upgrade here:
https://www.onshape.com/en/education/educator-upgrade
Hi Matt,
I'd like to laser cut the parts ofr the model bike frame challenge, however the link to the 1/4" laser cut sheet doesn't appear to load?
Am I missing something? - I can open the FeatureScript Auto Layout and see test cases etc.
Mr S Green UK
I think the idea is to just export the sketch named '1/4" Laser Cut' as a DXF for laser cutting. That sketch contains the parts for the test stand.
