What is with this new constant zoom out feature?
afalzate13afalzate13 Member Posts: 54 PRO
I don't know if it's just me, if I accidently touched something on the preferences or something, but it constantly zooms out on it's own to show the whole part. If this is part of the new update… please please please allow us to turn this off. This haunts me from the fusion 360 features of the software thinking it can re orient the view when it thought it was helping.
  • afalzate13afalzate13 Member Posts: 54 PRO
    Here's an example of the error, I wonder if it's just me since no one else commented: https://youtu.be/v1cqKprN3PQ
  • wayne_sauderwayne_sauder Member, csevp Posts: 628 PRO
    I doubt it is an onshape problem (I'm not seeing it). Have you checked for hardware or other software (driver) issues? I have had similar behavior when a mouse went bad.
  • MDesignMDesign Member Posts: 1,259 PRO
    If you use a mouse with a very light middle click and you use middle click to spin and scroll to zoom in/out it can act like a middle mouse double click to zoom to fit. try a different mouse if so.
  • martin_kopplowmartin_kopplow Member Posts: 1,066 PRO
    I once ha a badly calibrated space mouse doing similar things, only it kept zooming in. Some file where the calibration values were stored probably went currupt. Re-calibrating the device from the settings solved the issue.
    This was it! Thanks a lot man saved me from so much headaches.
