Hide the detail view external circle
Is there a way to hide the circle surrounding a detail view (1) in a drawing? You can set the color of the parent circle (2) to almost completely white (#FFFFFE) under (3) but there is no feature to get rid of (1)?
This is what I would like:
5
There is another workaround that is not parametric:
M
I can't guarantee this will work for you, but I've found that if I double-click the section view and then choose Edit detail, I can uncheck the box for Show detail view profile. Hopefully, that helps!
Thank you!
