📸 RenderCAD (One-Click Photorealistic Renders!)
MichaelPascoeMichaelPascoe Member Posts: 2,775 PRO
edited December 2025 in App Store & Partners Apps
Hi fellow Onshapers! I'm excited to finally introduce a project my friend and I have been working on for a while now.
This is a 1 click rendering tool lets you take a snip of your cad model and render it as a photorealistic image.
Literally a magic button that overlays your cad platform so that it feels like its a natural part of your cad environment.
RenderCAD
Supported Platforms
It's universal, so it will work with any cad system and even napkin sketches.
Pricing
New accounts get 3 free trial renders.
Pricing info is available on site.
Support
Software Formats
RenderCAD is available in the following formats:
  • Browser Extension
  • Desktop App
  • Render Studio Web Tab
  • API - For custom integrations
  • MichaelPascoeMichaelPascoe Member Posts: 2,775 PRO
  • S1monS1mon Member Posts: 3,985 PRO
    This is an impressive tool. What advantages does this have over Vizcom?
    @S1mon
    Vizcom is more of a broad creative sandbox, powerful with lots of control. While RenderCAD is built for immediate execution by giving the AI more control so that you don't have to mess around with settings. So RenderCAD's goal is to get you photorealistic results asap while leveraging the data you’ve already defined like model colors and geometry, to automate material selection for you. One of the main benefits RenderCAD has over other AI rendering platforms is the integrated snipping tool that lets you render your active viewport without ever leaving your cad environment. No exports, no uploads; just one-click and your done.
    Happy New Year! 🎉🎉
    Here's a BIG update!
    • 4K images
    • Video renders
    • Custom prompt instructions + Creativity slider option
    • And more 😎
  • martin_kopplowmartin_kopplow Member Posts: 1,218 PRO
    I tried to sign up for a trial, but they didn't succeed sending the confirmatoion mail (and yes, I checked my spam folder). Is there a secret trick?
    edited January 1
    @martin_kopplow on it!
    For some reason that email provider was blocking our automated verification message. You are now verified.
    Thank you. I'll try again as soon as I can.
    Okay, so I took it for a spin. I took for granted that it knows what a sofa looks like, and also how cars look, besides I cannot disclose any of the hypercars I am currently working on, so it had to be a new part, prefereably one the AI hadn't seen before. I chose a small connector dongle I had and took a screenshot:
    The prompt allows for 500 characters, but I kept it short: "Dark grey plastic for the housing. Nickel plated metal parts, brass pins, rubber connector housing and cable."
    This is what it came up with:
    Okay, pretty nice for a quick job. Lid of the housing is still light grey, the extrusions below the nuts are somewhat no man's land. Nice nickel effect.
    So let's get some more detail out of the same input: "Dark grey plastic for the housing and rear lid. Nickel plated metal parts, brass pins, rubber connector housing. Black PVC cable with horizontal print "ISO 9001" in light grey. Four wires are visible in the cut end face of the cable: One is red, one is blue, one is green and one is yellow."
    Here comes:
    Okay. It creates geometry of it's own, if required. Nice. Creating the mapping for the print on the cable would have taken at least a few minutes if I had done it manually, and the result here is sure good enough. It figured there'd be washers below each nut now, which there aren't. It didn't get the rear lid thing and it halluzinated a fifth wire and made it black.
    Well, some characters left until we hit 500. Here we go: "Dark grey plastic for the housing and rear lid. The cylindrical extrusions under the nuts are part of the plastic housing. A black cable-tie is inserted through the holes and goes around the housing and is closed above it. Nickel plated metal parts, brass pins, rubber connector housing. Black PVC cable with horizontal print "ISO 9001" in light grey. Four wires are visible in the cut end face of the cable: One is red, one is blue, one is green and one is yellow. Rotate the part 20° to the left."
    The result is as follows:
    Oops, that was unexpected. I need to explain the Zip-Tie thing better. The washers are still there. The rotation did not work out - which was to be expected, but I just couldn't resist trying.
    So, let's try something else and max out those 500 characters: "Dark grey plastic for the housing and rear lid. The washers under the nuts are intergral parts of the plastic housing. A black cable-tie is inserted in the slots at the side of the housing and closed around it. Nickel plated metal parts, brass pins, rubber connector housing. Black PVC cable with horizontal print "ISO 9001 certified" in light grey. 4 wires are visible in the cut end face of the cable: One is red, one is blue, one is green and one is yellow. Make the rear lid same color as housing."
    The result is:
    Small wonders are worked immediately, bigger ones maybe later: It automatically makes room for the longer text by extending the cable insulation a bit, which is kinda smart, though it does not know much about cable ties, still can't figure the slots and can't count to four. Also, it somehow deducted there'd now be a white background where it assumed a grey one earlier.
    So, what do we learn? It appears to be good at mainstream things, which it can do fast and with reasonable precision. I guess it'll be hard to get it to do specific details it hasn't yet seen. Unfortunately, the bulk of my work tend to be new things with quite some technical detail, and I have clients who would prefer illustrations to match exactly what they get, and I have NDAs I need to take care of.
    If I was to use this system for critical renders, I'd probably try to model all the critical elements in 3D, for that might still be faster than explaining it to the AI, and have the AI add eye candy like logos, prints, display content, things like that, which I usually do in Pghotoshop. That'll still save some time. For less important illustrations (the average PowerPoint) I might use it to create schematic renders, when it comes to comparing one general shape to another, black vs. blue housing and things I don't want to model or haven't modeled yet.
    I'll keep an eye open for this and maybe try a few more things next days.
    edited January 2
    Incredible feedback @martin_kopplow, many thanks!!
    We’re developing quickly and we definitely are open to adding new features and improving off feedback.
    And of course, we have no issues signing NDA agreement our users, if that matters to them.
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 724 PRO
    @martin_kopplow I've yet to mess around with this tool but I've messed with some local installs of controlnet and my own image generation stacks. I wonder if using deliberately contrasting technicolor color schemes in the model might help fix some of the ambiguity in cases like the washers vs housing body.
    edited January 2
    @Derek_Van_Allen_BD Our goal is to keep it the exact geometry, that's the intent. When giving it more creative freedom, and custom prompts, it tends to get a little creative. Trying to find the right balance so that it can still create, but also still keep the OG geometry unchanged.
    edited January 21
    UPDATE 📢
    RenderCAD.ai
    For those who missed the LinkedIn RenderCAD update, here is the latest stuff 😎
    Completely re-built rendercad.
    rendercad.ai is now💰6X cheaper per render
    ■ New engines to choose from: (Standard | Pro)
    ■ Choose product condition: (Clean | Slight wear | Heavily used | Dirty)
    ■ Render background color: (Auto | White | Grey | Gradient)
    ■ Custom instructions prompt: in case you need that carbon fiber look
    ■ 🎥Video camera presets: (Slight orbit | Rotate 360 | Pan and zoom)
    ■ Affiliate program: we pay you to make us look good, contact for details
    ■ Dark / Light mode: you're welcome
    ■ Re-branded site to dbrand/industrial/brutalist aesthetic
    ■ Well you read all the way down to entry 10... go try it out (┛◉Д◉)┛彡┻━┻
    @martin_kopplow We have a few things cooking based on the feedback you gave us. Excited to share that once it's ready.
    Another big update! 📢
    LinkedIn post:
    things are getting serious @ RenderCAD, dope new features:
    ■ Viewport: New dedicated viewport panel
    ■ Popout: Opens studio in a sleek browser window
    ■ Advanced Settings: New expandable panel for cleaner control
    ■ Condition: Tons of new condition settings
    ■ (Video) Engine: Tuned to better follow your inputs
    ■ (Video) End Frame: Control the ending (Loop | Upload, and more)
    ■ (Video) Motion Settings: Controls the targets motion
    ■ (Video) Camera Presets: Way more camera presets
    ■ (Video) Style Toggle: Choose Exact for strictness or Creative for flair
    ■ API Access: Added Auto-approve toggle for new overlay devices
    ■ Persistence: Hit refresh? Workspace now saves automatically
    ■ Comparison: Original vs Render now scales for closer 1:1 view
    This video only shows some of the new features, video changes will be posted in upcoming vids.
    Update for rendercad.ai
    Things are getting serious with this update:
    • Render iterations, the ability to take an existing render and render it again, building off of the previous render. For example use the mask tool to remove AI slop, or to add new material to different parts.
    • Up to 3 reference (image + prompt + mask) per render
      These give you the option to upload a custom image / material / background / or remove something from the image via mask guidance
    • Master background selection, will use up one of the reference slots on each image but apply the same reference background to be used for bulk rendering
    • Master material selection, will also use up one of the reference slots but will apply this material as the primary material for your render, slot can be edited so that it only affects the masked region.
    • Many more conditions including on-fire, red-hot, snow-covered, and more.
    • Material library, over 2500 textures
    • Background library, over 300 backgrounds / scenes
    • Conditions, over 40 different product conditions
    • Image editor, allows for some quick pre-processing to an image
    • Better seamless loop video options with an optional crossfade setting
    Is RenderCAD.ai based on something like Vizcom, or is it completely from scratch?
    edited February 10
    @S1mon the platform is from scratch. The backend architecture is headless and also from scratch, so we can instantly switch to whichever generative model is the latest and greatest (since that changes about every 3 months). We discussed making our own model but decided that would be a waste of time with companies like OpenAI and Google literally dumping billions of USD into the base technology. So next month if your renders look even better, this is why.
    If it's the latest and greatest, we will be integrating it for our users.
    Our roadmap includes technology that is on the verge but doesn't quite exist yet. For example: I would imagine that in a year, you will be able to upload some reference images to rendercad, and have a full 3d rendered model. That said, the tech isn't quite there yet and companies currently using this technique end up with half baked old game engine looking models.
    @martin_kopplow there has been quite a few changes since your last assessment. The renders you were trying to do previously should be trivial now that we have custom reference image + prompt + masking. This will enable you to select a region and tell it what you want to happen specifically in that region of the render. There is also iterative rendering now; so you can iterate on your previous render without having to do prompting guess work.
    @MichaelPascoe That's good news. I did not have much rendering needs in the past weeks, but I'll give it another spin ocne the current job nears completion.
