Why is Extrude Remove previewing correctly, then failing, but showing no errors anywhere ?
This should be a really simple project - make a box using flat panels with a couple of shelves inserted into slots. I created an end panel (flat 6mm sheet) and then try to remove 3 slots (3mm deep) by drawing a sketch on the top surface of the panel and then simply extrude remove 3mm down.
Everything previews Ok but when I confirm nothing happens. No errors showing anywhere. tried all the 'Merge with All' and 'Merge Scope' options - still no joy!
All suggestions welcome.
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 133 PRO
    edited December 13
    Did you try clicking the arrow to flip the extrude direction?
    Edit: Nevermind. I see the sketch is on the face of the part.
    You should share a link to your part so we can look at it.
    Ramon Yip | glassboard.com
