How to dimension to midpoint?
troy_ostrandertroy_ostrander Member Posts: 31 ✭✭
I am new to Onshape. Can't seem to find it easy way to do this. I'm sure there is.
  • Ste_WilsonSte_Wilson Member Posts: 535 EDU
    Might have to put a construction line/ centre line in there.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 696 ✭✭✭
    Or just a point. - Scotty
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,034 PRO
    Add a centerline, as a construction line. It will snap to the midpoint.
    Delete one of the circle dims and click on both circles then press the letter E, which will make them equal.
  • martin_kopplowmartin_kopplow Member Posts: 1,073 PRO
    Or, if you know the midpoint will be important, draw a midpoint line instead. It'll have a midpoint ex works.
    I think it is no good practice to dimension to an average line's midpoint because it might easily get corrupted in later edits. I always use an ecplicit axis for this reason.
