Answered: How to dimension to midpoint?
troy_ostrandertroy_ostrander Member Posts: 77 ✭✭
I am new to Onshape. Can't seem to find it easy way to do this. I'm sure there is.
  • Ste_WilsonSte_Wilson Member Posts: 564 EDU
    Might have to put a construction line/ centre line in there.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 747 ✭✭✭
    Or just a point. - Scotty
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,060 PRO
    Add a centerline, as a construction line. It will snap to the midpoint.
    Delete one of the circle dims and click on both circles then press the letter E, which will make them equal.
  • martin_kopplowmartin_kopplow Member Posts: 1,222 PRO
    Or, if you know the midpoint will be important, draw a midpoint line instead. It'll have a midpoint ex works.
    I think it is no good practice to dimension to an average line's midpoint because it might easily get corrupted in later edits. I always use an ecplicit axis for this reason.
  • troy_ostrandertroy_ostrander Member Posts: 77 ✭✭
    Thanks @martin_kopplow, line with midpoint is new to me thank you. The midpoint is very important to me and you said "….I always use an explicit axis for this reason." How do make an explicit axis?
    @troy_ostrander Just draw a line and make it 'construction', maybe even constrain it fix it in the sketch. A construction line used as an axis will allow you to dimension to diameter, even if you only draw one side of a rotational or symmetrical body. I guess that this will also eliminate the need to dimension to midpoint in 99% of the possible cases.
