UI vs featurescript query performance
forsaken_candyforsaken_candy Member Posts: 9 EDU
Hi, I've encountered a case where a simple query featurescript is a lot faster (2ms vs 2s) than a UI query feature. I'm querying all Body type entities created by a linear pattern.
https://cad.onshape.com/documents/edeb70c0a3255625e40a9ecf/w/dfb2fa469d1c4a18ede25477/e/508fd60f6cd5b2b24097410f
I'm happy to use featurescript, but since I'm learning, I'd like to know if this is expected and I'm missing something. Thanks!
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 389 image
    What happens if you turn off the “Show selection” option in the Query variable feature?
  • Caden_ArmstrongCaden_Armstrong Member Posts: 413 PRO
    turn off "show selection". Showing debug entities is very resource intensive.
  • forsaken_candyforsaken_candy Member Posts: 9 EDU
    edited December 2025
    Oh wow, that brought it down to 3ms. I had assumed that option only ran while the UI was open.
    Edit: This has shaved seconds off my regeneration times, thanks
  • Industrial_DesignerIndustrial_Designer Member Posts: 3
    What happens if you turn off the “Show selection” option in your Query variable feature.
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 188 PRO
    Huh. Well, today I learned…
    Ramon Yip | glassboard.com
