Featurescript: Setting parameters to optional
ry_gbry_gb Member, csevp, pcbaevp Posts: 167 PRO
edited December 2025 in FeatureScript
Let's say I create a feature and then want to import it into another studio feature studio for use. Is there a way to make some of the definition parameters optional?
Edit: edited for clarity
Ramon Yip | glassboard.com
  • _anton_anton Member, Onshape Employees Posts: 510 image
    Really, all parameters are optional unless they're used in the code of the feature. If you want the UI to communicate that a parameter isn't used, you can use if statements to hide it.
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 167 PRO
    edited December 2025 Answer ✓
    • Edit: argh. I didn't mean to mark this as an answer, but i can't undo that. Everyone else answered very well.
    • I guess I should expand a bit more. I've been working on the Loft Fillet featurescript that I posted a while back. And as an added feature, I've also been working on an option to auto-match connections inside of it. It's starting to look like Auto Loft Connections might be a useful standalone feature by itself as well. I could just copy the code from Auto Loft Connections, turn it into a function inside of Loft Fillet. However, it would be rather tedious to keep up in both files should I ever change the code from Auto Loft Connections and the function inside of Loft Fillet.
      I'm not entirely sure what Auto Loft Connections will end up looking like yet, but I'm wondering if there's a way to set myself up so I only need to change the code in one script and then deal with the ramifications on the dependent scripts after that. Would it be better to set up a third feature studio and import them both into Auto Loft Connections and Loft Fillet?
    • Secondly, how does that get implemented in the standard library functions? For example, in opExtrude, startBound is stated as optional, but as far as I can tell, there's no boolean or if statement driving it? Unless there's something in the internal code that I'm not aware of.
  • MichaelPascoeMichaelPascoe Member Posts: 2,763 PRO
    You can conditionally show and hide UI like this: https://cad.onshape.com/documents/c7c08274a0d273b9a5f5b47d/w/f348f21ad2fa5c8771f1e1b1/e/0abb9be049d15f1839c40841
    This can be controlled manually when you insert functions, or dynamically with either user choices or edit logic.
  • jelte_steur_infojelte_steur_info Member Posts: 638 PRO
    If you create an opCreateMatchConnections function separately in its own feature studio in a document, you would be able to import it in AutoLoftConnections as well as the Loft fillet feature and get the benefit of version control where you might update it in one feature and deal with ramifications while the other one stays put until you get to updating it there.
    I think the ‘optional’ functions all have a default or fall-back setting for if the argument is undefined.
    In your opExtrude example (speculating here): if (definition.startBound != undefined)
    {offsets the starting faces or edges by startBound value}
    So if startBound is not used, it’ll still just work with the original faces or values…
    these were my 2 cents. Would be very curious to hear what @Caden_Armstrong’s advice is on this matter of when/how to split functions into their own feature studio.
  • EvanReeseEvanReese Member, Mentor Posts: 2,788 PRO
    @ry_gb I'd get the key steps put into their own functions, which can be used as needed in either feature. Those functions could live entirely in their own feature studio and be imported to the feature studio for Loft Fillet and Auto Loft Connections.
    As for conditional UI things others have covered it, but you just need to write your code in such a way that it doesn't fail if they don't use a certain field. For example if you have an optional query parameter you might do this
    if(isQueryEmpty(context, definition.pointReference))
    // If the query is empty, decide how to proceed without it. Maybe you don't need to do anything special, or maybe you wanna set it to something like this
    definition.pointReference = qOrigin(EntityType.BODY);
    // OR
    definition.pointReference = qNothing();
    else
    // Do whatever you want to use the reference
    // OR
    else
    Thank you all. These are all great answers. Seems pretty simple, but you need to be very explicit in how different inputs are entered.
  • Caden_ArmstrongCaden_Armstrong Member Posts: 381 PRO
    Not sure how much I have to contribute - I think the thread captured most of what needs to be said.
    For the unaware - the mergeMaps function can be useful for defaults/optional values. If you take a map of default required values and merge it with the input map to a function, you can easily handle missing parameters without having to null check everything.
    That's really cool. Thanks for for the extra tip.
