How do I constrain only 1 degree of freedom?
I'm new to Onshore (coming from Inventor and Solidworks, and I generally like the mate connectors for constraining things together just cause you can lock all 3 degrees of freedoms with a single constraint.
However, I'm trying to layout furniture in a room and it would be nice if I could do an Autodesk Inventory style mate where I mate the plane of the floor with the plane of the furniture feet and then still drag them around in the X and Y direction. Is there an easy way to do this in Onshape?
Thanks,
  • jelte_steur_infojelte_steur_info Member Posts: 656 PRO
    It's called planar mate
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 953 PRO
    Fun fact: once you've defined a mate with two mate connectors, you can change the mate type at any time.
