Drawing template doesn't show up
mechanical_cadmechanical_cad OS Professional Posts: 24 PRO
edited October 2016 in Drawings
Hello, I follow the steps on the link below, exported the DWT, imported it, but when I go to Created by me Filter the template doesn't show and I can't use it. Where may be my mistake? Thanks!
https://cad.onshape.com/help/Content/templates-custom.htm
  • erik_bongerserik_bongers Member Posts: 16 ✭✭
    Same here. Why is there no answer to this question?
    Apparently, after you import the DWT file, you have to right-click on it's tab and select "Create a drawing of...". Then it will trigger the DWT to become a template. Also, after that step you can delete that drawing you just created (if not needed).
    The documentation for this should be updated!
  • stanko_golocorbinstanko_golocorbin Member Posts: 2
    I created a new document inside of Onshape and created the template there. Now its always pulling the drawing template from that document(shows in "created by me")
