new custom feature: Boolean Variable
jelte_steur_info
Member Posts: 655 PRO
Happy winter solstice to everyone!
I was grouping some dynamic suppressions in a configurable document and creating a regular variable, setting it to 'any' and creating an equation, (or typing "true" manually.)
This bothered me, I figured this should be easier if I'm going to do this a lot.
so I created a dedicated:
Boolean Variable
I should do something like this for doing directional flipping when you enter negative values for things like offsets or move faces. Save myself the need to remember the expression syntax.
Derek Van Allen | Engineering Consultant | MeddlerI just did this the other day. It didn't seem like a lot of effort, but I can see that it would get annoying if I had to do this a lot. Adding this to my toolbar.
Ramon Yip | glassboard.com
@Derek_Van_Allen_BD.
I imagine this as an "absolute variable" FS that takes in a variable and outputs two new ones, reusing the names etc.
input: #offset
output: #offset_abs (is same type as input).
#offset_flip (is boolean)
The native variable feature really should have a "Boolean" option (in addition to "any")!
