Curving text
What is the easiest way to curve text on any surface/shape?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 861 PRO
  • jnewthjnewth Member, OS Professional Posts: 88 PRO
    Hi @Grav_electric I recommend people use my new feature "Text". You can get it here:
    https://cad.onshape.com/documents/4e187c2b2f7f4974f4e2b612/v/a94c2b1949ec131c8d9eb61f/e/3458f1d46464375effca78a5
    You can draw a path or a curve on any surface and then distribute text along it as needed. It has a number of manipulators to make text orientation and position easy to adjust: you can read about it here:
    The newest release 3 adds kerning control and a few other useful controls:
    And it all works on surfaces as well:
  • Grav_electricGrav_electric Member Posts: 20
    thanks
  • colin_haycockcolin_haycock Member Posts: 2
    Great tool, thanks.
    Is there a way to control the spacing between the letters so that the space between the lettrs is consistent?
    Here's an example of what I mean; the spacing between the letter I and the others appears different because the letter itself is narrower but the bounding box for the letter doesn't take account of that.
    @colin_haycock Yes, you can totally do that. What you are asking for is "kerning" which for various reasons is hard to make work the way you'd want (which is: automatically). The feature provides that control via "Adjust offsets":
    When you enable "Adjust offsets" a point manipulator appears on each letter (the white dots). You can click on the letter you want to move and drag it left or right to position it:
    And tweak letters in this fashion until you are happy with the result.
    Hope that helps!
