new custom feature: Boolean Variable
jelte_steur_infojelte_steur_info Member Posts: 650 PRO
edited December 2025 in FeatureScript
Happy winter solstice to everyone!
I was grouping some dynamic suppressions in a configurable document and creating a regular variable, setting it to 'any' and creating an equation, (or typing "true" manually.)
This bothered me, I figured this should be easier if I'm going to do this a lot.
so I created a dedicated:
Boolean Variable
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 822 PRO
    I should do something like this for doing directional flipping when you enter negative values for things like offsets or move faces. Save myself the need to remember the expression syntax.
    I just did this the other day. It didn't seem like a lot of effort, but I can see that it would get annoying if I had to do this a lot. Adding this to my toolbar.
    Ramon Yip | glassboard.com
  • jelte_steur_infojelte_steur_info Member Posts: 650 PRO
    @Derek_Van_Allen_BD.
    I imagine this as an "absolute variable" FS that takes in a variable and outputs two new ones, reusing the names etc.
    input: #offset
    output: #offset_abs (is same type as input).
    #offset_flip (is boolean)
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,598 PRO
    The native variable feature really should have a "Boolean" option (in addition to "any")!
