Distance between 2 drawings in the Drawing Studio
ProApeProApe Member Posts: 212 ✭✭
edited January 4 in Using Onshape
Hi,
How can I determine the horizontal and vertical distance between the two parts in Drawing Studio and set the distance? This is important because I want to mill the parts and it is important to know the distance so that there is enough material left between the parts.
I also want to draw a circle x mm away from a bottom corner to have a reference point for milling on both sides. How can I do that?
I have noticed more and more often lately that Onshape has problems opening a sketch. A coloured wheel spins continuously. So far, closing the document and then reopening it has always helped.
https://cad.onshape.com/documents/5f802a490cf8cf9e071ba9f4/w/4e428266eaca212f41ecca1b/e/8fcc7cbc7bbb8c0c7aaa65f1
Kind regards
ProApe
P.S.: I wonder if the link I copied like that in Onshape is correct, as it is not blue. I tried a second time with the same result.
