Shortcut indication on tools and contextual Menu
francois_carlettofrancois_carletto Member Posts: 5 ✭✭
Hi all
In Onshape, keyboard shortcuts are essencials, however, exept having a printed list of keyboard shortcut on the side of the computer (or using the help shortcut list), it is not easy to determine what shortcut is for what action.
Could be implemented the following idee:?
By a flyover of the button or on the right of each action in the contextal menu, could you please add the correspondant shortcut for each action?
That help the learning of it.
Thanks a lot.
  • SethFSethF Member Posts: 132 ✭✭✭
    edited May 2022
    I think all the tools that have a shortcut do list the shortcut in the flyout if you hover over the tool before selecting it.
  • edo_plantingaedo_plantinga Member Posts: 6
    I support this! This works great for the tools in the toolbar, but not for the contextual menus, even though the contextual menus have actions in them that are used often. There is no easy way to discover that "View normal to" in the context menu has the 'n' as a shortcut, for example.
