How to update all linked document tabs within a Publication
jonathanb_sydney
Member Posts: 33 PRO
I have a Publication with 15 tabs all linking to the same Document. When I uprev the Document, I need to a) select each Publication tab, b) select update document, c) click OK.
Is there a way all tabs, or at least all tabs linking to the same Document can be updated to a later revision within a Publication?
1
hi, Did you find a way to update all the tabs in one go in a publication? I need to do the same.
The SmartBench app Renaissance has a tool for publication updating.
It can update all the tabs in a publication to either the latest version or latest release.
unfortunately, i did not. i just managed with the 15 tabs when we released versions about once a month. it was annoying but manageable. Maybe @Caden_Armstrong solution might do the trick for $30/month
