Not possible to place a sketch on top of a part
ProApe
Member Posts: 226 ✭✭
Hi
Why can't I place a sketch on the surface of the trunk?
https://cad.onshape.com/documents/0e7bb6cd58a560d9f21d8f78/w/be03cb90fb378a45df2c692f/e/88e3a2d3ca60d02b82f239c5?renderMode=0& uiState=696e1a24c2e41601c399a967
Kind regards
ProApe
Link broken/missing - error message "Cannot open document in trash"
CADNurd's Linktree - find me everywhere else - https://linktr.ee/Liam.G
Sketches must require a flat plane. Is the surface you are trying to create a sketch on flat? - Scotty
"Link broken/missing - error message ‘Cannot open document in trash’"
Could this be because I inserted the link into my message, but didn't post it until hours later, and in the meantime I continued working on the document?
Yes, the surface is flat. I just deleted everything I had added since the link to reproduce the situation, and I was able to place a sketch on the surface without changing anything on the body. Strange.
Since it didn't work yesterday, I worked around the problem by creating a plane at the height of the surface and placing the sketch on it.
