How is Surfacing in Onshape vs. SolidWorks in 2026?
Chris_Beckett
Member Posts: 9 ✭
in General
I have done a fair bit of surface modeling in SolidWorks over the years.
Now considering Onshape and I'm wondering:
- How is the quality of Onshape’s surfacing tools compared to SolidWorks?
- Does Onshape have all the same surfacing functionality as SolidWorks?
- If not, what's missing?
- If so, is it just as easy to use in Onshape? (ie not any more difficult).
- How is the quality of the surfaces that Onshape creates compared to SolidWorks?
The only answers I found in Google were from years ago. Onshape may have changed quite a bit since then (it seems).
What has been your experience, experienced surface modelers?
Personally, I much prefer Onshape to Solidworks these days. There's a bit more control of most things, although a true 3D sketcher is missing. You can do just about everything you'd need with the other curve tools (routing curve, bridging curve, edit curve, etc), but there's no 3D solver. The 3D solver in Solidworks was always pretty brittle/buggy and stuff would blow up in weird ways.
Surface quality is as good or better. The surface analysis tools are more capable. Both are Parasolid based, as you probably know. In theory anything that can be represented in NX, Solidworks, Shaper3D, Plasticity, etc can be modeled in Onshape since it's all the same kernel.
There are a lot of a little quality of life things that could be improved here and there, but overall I'd rather work in Onshape.
The CAD for these below was all done in Onshape:
Thank you @S1mon. Your insights and photos are a big help. That headsets photo is stunning.
@S1mon is top tier at this stuff!
Hey @Nick_Holzem, you should post some of your work here!
One thing that really changed the game for me in Onshape was the ability to Edit Curves. While you can't do directly create 3D sketches, I'm mostly using projecting 2 sketches to create the 3D curve. From there you can use Edit Curve to reduce the point count (even down to single-span) and create much cleaner surfaces. SolidWorks doesn't really have that functionality and creating 3D sketches to replicate those projected curves is very tedious and difficult.
Ramon Yip | glassboard.com
Oh I guess I should have dropped my surfacing video here too.
Thanks Evan. I will try to watch this.
Have you done surfacing in SolidWorks also?
How would you compare the two?
I have but it was 9+ years ago. Onshape can handle anything I'd have done in Solidworks. The real tell will be you doing a model in Onshape and asking here for specific troubleshooting help to see for yourself.
I would also check @GregBrown's channel as there are some good "deep dives" into Onshape's surfacing/curve tools:
Here's an example (from a year ago, so there have been things added since) that might be useful:
There are also some good videos on the face blend feature and a very recent one on Conic surfaces that is more of a "preview" of upcoming features but also features a lot of general Onshape specific surfacing functionality.
Thank you. That's what I'm doing right now. Currently frustrated by how many more clicks everything seems to take in Onshape vs. Solidworks.
I'm currently having to rebuild in SolidWorks some models that we built in Onshape and it's been ruffffff…
Onshape has so many quality of life features that I've now started to take for granted. And this is after 10 years of SolidWorks and 2 years into Onshape.
The one thing that I DO dislike is that in Loft, Sweep, and Boundary Surface, you need to expand the selection boxes to keep each selection grouped. Otherwise, I enjoy not needing to convert entities to create a new sketch if I want to keep my feature tree from absorbing my layout sketches. Currently, I'm constantly having to fight that in SolidWorks.
Can you share some of the quality of life things you mention? How is Onshape better at surfacing?
I've been trying to model a part I did in SolidWorks years ago. So far it seems to me like the SolidWorks workflow is more streamlined.
But I only started Onshape a few days ago, so I'm asking more experienced users.
As far as I know, Solidworks still can't tell you how complex a surface is (e.g. degrees, spans and knots). I used to export to Rhino just to see what the isoparameters were to see how crazy a surface had become. This is built into the curvature evaluation tools in Onshape. The boundary surface tool in Onshape is better about taking existing input curves and keeping the surface as simple as possible. Loft in Solidworks (and Onshape) just wants to make really heavy multispan degree 3 surfaces which can cause a lot of downstream grief with complex models.
Bridging curve with G3 on both ends is very powerful 3D tool. Solidworks still only does a "torsion" constraint (G3) in the 2D sketcher.
Custom features add an incredible amount of power to Onshape. If you need custom airfoil shapes (or gears, etc.), for instance, there are features for that.
The Edit Curve feature (with approximate, raise degree, and planar) starts to approach some of what you can do in Alias, Rhino etc. It's not going to fully replace those, but it does a lot to get good quality curves in a mechanical CAD tool. There's nothing like it in Solidworks.
If we ignore surfacing for a moment, I would say the way that history, version control, and reference management work is really the fundamental reason I do not want to work in other tools. I've spent 30+ years using Pro/E and Solidworks for complex consumer, medical and industrial products with a lot of top down design. Managing those references in other tools was doable, but there were a lot of pain points that go away in Onshape. I also basically never loose work in Onshape. I cannot say that for any file-based CAD system I've used, even with professional PDM tools in place. I managed Solidworks EPDM (now PDM pro) for 8 years. Again, I would not go back to that. Yes there are a few things here and there that are missing in Onshape, but overall the ease of use and ability to freely experiment safely is life changing.
Obviously you know your way around CAD but if you have only started working with Onshape, you haven't had a chance to get used to the "basic" little quirks and features and I suspect you will either figure out how to eliminate the extra clicks, or even if there are some parts that require more intermediate steps, not crashing and losing data plus not having to worry about when to save etc… will more than make up for a few extra clicks here and there. And if you have some specific workflows you repeat often, custom feature could save you a ton of time.
If you have some examples you are able to share, we may be able to comment on the workflows and potential optimizations.
Not to mention the incredible community of support here with Onshape! You're talking to the top contributors here - they share decades of high-level experience and unbridled enthusiasm for getting work done efficiently in Onshape, while figuring out how to push the boundaries. It's a true differentiator - the quality of discussion is very good.
Also - the senior leadership and developers of Onshape itself participate actively on this forum. When you get incredible comments and learning materials like the @GregBrown videos linked above, you are getting the very best of the product and the company here.
Welcome!
@S1mon covered a lot of what I was going to mention.
Bridging curve is fantastic and make it very easy to create clean curvature. Edit Curve also allows you to create really clean curvature (but as mentioned, not quite to the level of surfacing specific CAD tools).
Onshape also has implemented quite a few analysis tools that are missing in SolidWorks. In particular, they just recently implemented a tool to check for G0, G1, and G2.
As far as additional quality of life improvements:
- Pretty much everything is parametric in Onshape in a way that you would think that SolidWorks should be. Recently, I've been using variables a lot to drive my models in both SW and Onshape. In SW, you can't enter variables or equations into the input fields for some features. Ones I've run into so far as Helix, Plane, Scale (and others, but they escape me). The workaround using Instant3D is really frustrating and also doesn't work with Scale. It also gives you an potential circular warning error sometimes when there is none.
- Autocomplete for Global variables is half-baked in SW. Variables don't autocomplete if they come later in an equation. For example
'= 10mm + "myVar".myVarwouldn't autocomplete in this case and you also just have to know what the variable name is.- Configurations are much better implemented in Onshape. You're allowed to mix and match different configuration settings as opposed to needing to create nested variations for each config you have. Also, in SW you can only configure dimensions and feature suppression. In OS, you can configure pretty much anything inside of a feature. For example, in Extrude, you can configure supression, end condition, selections, draft, directions, etc, etc.
- Onshape in general seems to preserve references a lot better. Particularly for sketch splines and G2 constraints, SolidWorks keeps losing my references even though I'm referencing sketches instead of faces/edges/geometry when I change my dimensions. Funnily enough, this is known behavior and requires another weird workaround through the use of helper sketches.
- The implementation of Query Variables takes robustness to a different level in a way that approaches Grasshopper levels of smart-ness. There's a whole lot to unpack there, but suffice to say, there's nothing else like it in any other parametric CAD package. @EvanReese has a great video on the topic: Query Variable.
- Also, Dassault decided to lock their forums behind an account wall and I will forever hate them for that. Needing an account just to read some forum post just screams Dassault all over.
I've used SW for 20 years. Sure it's got the 3D sketch. Is it stable? Not always, from my experience. I believe when it comes to advance surfacing, it's more about the approach than the CAD system. So when I hear SW is better for surfacing, what I actually hear is: "I've developed my surfacing approach around SW and don't know what I'm missing out on in other systems." OS surfacing can be more involved up front; way more stable down stream. I've been surprised at rolling back the bar and seeing it rebuild first try without any issues. SW lets you get away with things, that then go on to cause issues later on. The best thing about OS, you still get issues but doesn't crash, so you can stay in the flow to fix and learn better for next time.
