Duplicate feature (or copy feature settings) in the feature tree
Richard_Inv
Member Posts: 40 PRO
in General
This would save on having to re-enter settings. For example, say I want to duplicate a Linear Pattern feature, but changing the direction while keeping everything else the same.
Currently I have to create a new feature and fill everything out again.
The SmartBench app Renaissance has a tool called "Duplicate Feature" that lets you select multiple features and it will insert copies into your part studio.
The only challenge is that the selections are copied exactly, so in this example you can see that I have to go through and modify the selections to get the result I want.
